Old 01-01-2009, 07:51 PM   #1
ddwilliams5
Unhappy help my ford laser nobody else can seem to
Hi,
I have been to 2 mechanics now and no one seems to know whats wrong so heres the thing:
I start it fine of a morning reverse out the drive put into first gear and off I go but I have no acceleration I have to push the clutch and accelerator together like Im about to do a burn out to get the fuel through and I am fine, this goes on continuously for about 5 minutes once the car has been going for 5 minutes its fine, now if I was to come home and park it for half an hour it will do it again, wouldnt matter if I have been driving for 20 minutes or 2 hours.....I have had the fuel injectors done but that didnt fix the problem, she is a Laser Liata 1.8 1984
ddwilliams5 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2009, 08:33 PM   #2
SNB05T
Dan Brown Photography
SNB05T's Avatar
check your fuel filter, it may be clogged. while you're there check spark plugs and leads and air filter.
Building a barra Play car slowly
daily and off road: 2021 Ford Everest Trend
Project Barrage: 2005 BA MK2 XR6 Magnet Falcon ute. the fun begins
SNB05T is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2009, 12:47 AM   #3
ddwilliams5
sorry negated to advise that the fuel filter has also been replaced along with plugs and leads....I m thinking fuel but to be honest have no idea
Old 02-01-2009, 04:34 PM   #4
MaTTe
it could be the fuel filter inside the tank on the fuel pump is the problem. or could be a fuel pump on its way out, but it'd give more problems than just when starting up..
Shed cleanout.. Pictures and prices here
Dynamat type product Group Buy Here(Round 2)
MaTTe is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 11:38 PM   #5
Krytox
Krytox's Avatar
94'?
Cat converter?
If' she's done High K's, it could be a little tired.
CareFree....
we may not be No.1 but we're Up There
Krytox is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2009, 12:03 AM   #6
290v
290v
290v's Avatar
could be a the head gasket leaking water into one of the chambers running rough until the chamber is clear of water again have you tried removing the leads one at a time to see if one cyls are working?
BA GT 2003 Silhouette
4 Speed Auto
290v is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2009, 02:08 AM   #7
LESLIE G
OMG NOT AGAIN! DAM FORDS
Default maby
IM takeing a stab in the dark here prob first thing that got looked at but have you checked the auto choke ? sounds like it to me it could be flooding the car causing the splutteing (reving helps because it sucks more O2 into the car giving correct air/fule ratio) then when it warms up choke comes unstuck and runs fine ?? had a verry simula problem with a old magna i had
anyway good luck post back let us know how you went on :
Sppellling is irrelevent...irrelivant...irrelevant...**** it! :
LESLIE G is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2009, 10:56 AM   #8
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Injected cars do not have an auto choke.
Have you left the car with them overnight, so they can try it when it's cold?
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2009, 07:41 PM   #9
ddwilliams5
Unhappy
They had the car for 4 days, when we replaced the leads and plugs one of the plugs had a lot of oil on it, since they have been replaced its not running as bad but still doing it it seems to only be in 2nd gear its driving me nuts and I need help cant afford to get a new car for another 12 months....
Old 21-01-2009, 08:16 AM   #10
ddwilliams5
and the winner is....
Old 21-01-2009, 08:52 PM   #11
290v
290v
290v's Avatar
thought so had a few dealings with Lasers have 3 in the family
4 Speed Auto
Old 24-01-2009, 12:22 AM   #12
290v
290v
290v's Avatar
this is short term but Cemi weld does work just follow the instructions my friend had no money to fix his car so i told him to keep it running it lasted another 2 yrs before the head had to come off (Last resort) but when you come to fix it properly you will have the radiator flushed and the block to remove it all
4 Speed Auto
Old 24-01-2009, 09:03 AM   #13
wesomc
wesomc's Avatar
Does it seem to be blowing an unusual amount of steam out of the exhaust? Usually a good indicator, has it been using any coolant?
could also check compressions, fuel pressure, Engine Coolant Temp sensor.
White MY04 Subaru Impreza WRX Hatch - Stock, airbox resonator mod, lowered on king springs
Marine Blue EBII XR8 - GT40p's, Paceys, 3in mandrel bent exhaust, Explorer Manifold, YT 1.72 RR's, 65mm TB, 75mm MAF, Thermo's...now manual
1967 Ford Futura coupe 289 C4 stock cruiser
wesomc is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2009, 06:04 PM   #14
ddwilliams5
Have to refill the coolant every 2 days after only traveling to and from work approx 30KMS
Old 24-01-2009, 06:06 PM   #15
ddwilliams5
Sold it for a grand, off to buy a new car tomorrow it was a piece of crap anyway not worth spending anymore money on.....thanks for your assistance though, greatly appreciated...
