Old 24-06-2007, 08:28 PM   #211
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
I have a couple.
(1) Is there a part number for the BA ICC Harness from BEM interface J4 - ie, the harness that always drives the Remote Key Receiver, but also has variants that drives the ICC Video input, Cabin Temp Sensor and Clock? I've searched with most of those as keywords without much luck.
(2) Is there a Part Number for the courtesy light with integrated switch that you see over the rear seats in BA XR's, and in behind the Sunvisor in Fairmonts and above? Once again, keyword searches have drawn a blank.
(3) In your database I found mention of the part number AU2 17E704 A 'MODULATOR MIRROR CTR, WITH MEMORY MIRROR' when searching on the word 'Mirror' and selecting BA. Since I'm interested in adding Memory Mirrors with Reverse Dip - is there any chance that anyone knows what this module is and what it does? It's not listed in the BA Workshop Manual anywhere. I've often been curious as to how the Memory Module under the seat could control the mirrors, and have been suspicious that there's another undocumented controller somewhere - and this is the first possible evidence of something like that.
Luke
If the human brain was simple enough to understand, we'd be too simple to understand it.
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2007, 12:14 AM   #212
russellw
russellw's Avatar
Originally Posted by Luke Plaizier
I have a couple.
Luke
(1) Looks like this is actually part of the main wiring loom.
(2) There are 2 seperate parts that make up this lamp but it is available as a kit:
BA 13A701 A LAMP ASSY - 13.40
(3) You are correct in your assumption as it is only fitted to vehicles with Memory function. The little pic below is it in diagrammatic form.
Russ
Old 28-07-2007, 08:30 PM   #213
Texas
The Beast
Texas's Avatar
Hi Russ , a mate of my has got a au Ford trying to fit a Au Hawk front grill, holes line up but there is a gap of about 2-3 inches .From bonnet to grill is there another part he needs?THANKS.
Texas is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 02:31 PM   #214
russellw
russellw's Avatar
There is a little infill panel that was used on the AU -
AU2 8C104 A Moulding, Radiator Grille 52.10
Russ
Old 30-07-2007, 06:46 PM   #215
Texas
The Beast
Texas's Avatar
Thank You So Much Russ . Cheers & Beers,
Old 13-08-2007, 08:41 PM   #216
normell
Hi Russ
The plastic guard type thingie, under the front lower bumper has split, makes a load of noise.
Question is do you have a part number & price, and would a second hand unit do.
Normell
Every day above ground is a good day.
Still Drinking & Driving, But Not At The Same Time
normell is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2007, 11:33 PM   #217
russellw
russellw's Avatar
I presume you are referring to the undertray that sits under the engine?
I can't find a listing for it but a 2nd hand one would be fine I would think - they don't seem to last very long anyway and it is better to use screws and speed nuts rather than refitting them with the bloody useless xmas tree clips.
Russ
Old 11-11-2007, 03:46 PM   #218
sly
Sly like a G6
sly's Avatar
I think it's called a "deflector", kinda rings a bell, I've had 4 in 320,000km & have given up replacing them for now.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2007, 04:02 PM   #219
Mechan1k
Mechan1k's Avatar
Russ
That reminds me ... I need to put mine back one ... with something stronger.
Old 19-12-2007, 01:51 PM   #220
gregsAUII
Me AU's cheap and clean.
gregsAUII's Avatar
Part # Description Unit Price
TAU 17C831 A COVER FRT BUMPER BAR, PAINT TO SUIT, T-SERIES $257.00
TNUTVE 17D749 A INSERT FRONT BUMPER, PAINT TO SUIT, T-SERIES $502.00
Unique bits only
Thats not the price for the bars is it $257.00 $502.00???
THE MIGHTY MANLY WARRINGAH SEA EAGLES
Daily - 2013 SR5 Hilux
Toy - 2000 AUII Falcon
Toy - 2010 Kawasaki ZX10-R
Her's - 2017 Camry SX
gregsAUII is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2007, 08:16 PM   #221
russellw
russellw's Avatar
No - just the cover and insert.
Russ
Old 30-01-2008, 07:28 PM   #222
fourl6
AU Falcon Man
fourl6's Avatar
ER 10C975 A KIT CRUISE CONTROL, CONVERSION KIT - MAN TRANSMISSION, FORTE/S/XR6 $70.20
am i correct in thinking i can fit cruise control myself for around $70...?
also is this the red stripe in the doors of the AU XRs...?
ERT F254A59 A MOULDING INSERT LH, RED, ALL EXCEPT HOT CHILLI RED - P4, XR $11.05
ERT F254A58 A MOULDING INSERT RH, RED, ALL EXCEPT HOT CHILLI RED - P4, XR $14.04
ERT F20861 A MOULDING INSERT LH, RED, ALL EXCEPT HOT CHILLI RED - P4, XR $17.68
ERT F20860 A MOULDING INSERT RH, RED, ALL EXCEPT HOT CHILLI RED - P4, XR $17.68
and are these is the front and rear bar stripes...?
ERTVE 17D889 A TRANSFER F BUMPER RH, RED, XR $13.39
ERTVE 17D934 A TRANSFER F BUMPER LH, RED, XR $13.39
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2008, 01:42 AM   #223
fourl6
AU Falcon Man
fourl6's Avatar
anyone...?
Was
Old 03-02-2008, 03:17 PM   #224
russellw
russellw's Avatar
On your first point the answer is no. That is only the conversion kit.
You are correct with the body side mouldings.
The front bar transfers are not the moulding as it is listed on it's own but it's not clear from the diagram what they are. There are a similar set for the rear bar.
Russ
Old 03-02-2008, 03:52 PM   #225
philstoj
philstoj's Avatar
Hey Russ, can you check if floor carpet is still available for AU XR ute or sedan?
Also price please.
cheers, phil.
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2008, 11:21 PM   #226
russellw
russellw's Avatar
Sedan appears to still be available:
ER F13000 A6 CARPET, 4 DR SED, FORTE/FUTURA/S/XR, WARM CHARCOAL $ 664.30
Can't find a listing for the Ute but it is likely to also be available at about half that cost.
Russ
Old 04-02-2008, 12:16 AM   #227
philstoj
philstoj's Avatar
Thanks Russ.
Old 13-02-2008, 11:07 PM   #228
AU1XLS
AU1XLS's Avatar
Russ
Ute carpet AUC2 P13002A6 Warm Charcoal (No Longer Available)
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 02:13 PM   #229
GTsteveMkII
EL GT 082
GTsteveMkII's Avatar
Does anyone know if the little T-Series badge that is in the centre of the dash on automatic TE50's, TS50's and TL50's (excluding T3 TE50) is still available and what the part number is? Thanks.
GTsteveMkII is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 07:18 PM   #230
T3man
T3man's Avatar
The part number is
TAU F04460 A
Sadly no longer available (see your other thread). However if you can get one ... get two! I'll have one please. BTW the list price was $27.90 the last time I bought one.
Old 09-11-2008, 05:22 PM   #231
JeffAU1
JeffAU1's Avatar
Default Missing Part
Hi
I need to know the part number for the item in the picture and price if you know. Its for a au1 Falcon Sedan.
The left hand side front cover fell off after my last service.
Thanks
Jeff
:eclipsee_ MY CAR :eclipsee_
JeffAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2008, 06:57 PM   #232
russellw
russellw's Avatar
ER F001A06 A DEFLECTOR AIR FRT RH, (-)XR - about $13
Russ
Old 29-04-2009, 05:12 PM   #233
5L
[ 5L ]
5L's Avatar
anyone know the part number for the REAR IRS MOUNTS?
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2009, 06:19 PM   #234
russellw
russellw's Avatar
If they are the ones I am thinking of then:
AU2 5T120 B (RH)
AU2 5T121 B (LH)
Old 09-01-2010, 01:52 AM   #235
EgoFalcon
The Villan
EgoFalcon's Avatar
Whats another name for the side guards?
New addition! 2010 FG XR50 Turbo in Lightning Strike
The PX Ranger has arrived! XLT Metropolitean Grey
Previous Ride - 2007 BF MK II XR6 in Lightning Strike
EgoFalcon is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2010, 02:58 PM   #236
russellw
russellw's Avatar
When you say side guards I presume you mean the bodywork at the front side? If so, they are referred to in Ford speak as fenders.
Russ
Old 03-04-2010, 04:04 PM   #237
Tezbo-BAXR8
I have a set of ACL Duralite pistons that came out of an XD motor that I built years ago. The engine had a crack in the block and was pumping oil into the water. Very dissapointing at the time, but does anybody know wether I can uyse these pistons in an AU block?
Tezbo-BAXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2010, 01:04 PM   #238
fordmuscle
fordmuscle
Hi I just purchased a AU XR8 SERIES 2 I'm wanting a set of headlight protectors any idea on price of new or second hand thanks fordmuscle
fordmuscle is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2010, 01:19 PM   #239
russellw
russellw's Avatar
ER 13000 B HEADLAMP PROTECTORS, FITTING TOOL MUST BE USED, XR - around $100 for the factory units.
Russ
Old 30-05-2010, 01:33 PM   #240
UU TS50
T3 TS50 075
UU TS50's Avatar
look on ebay they are there alot and go for around $70
Cheers John
My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw
UU TS50 is offline   Reply With Quote Multi-Quote with this Post
