I have read somewhere that Ford brought some TC's in from South Africa with the 3lt v6 in them for evaluation prior to launching the TC 6 cylinder. I do remember one at Summernats a while back with NSW plates VEE 600 but other than that nothing.
Does anyone have any info???
ED XR6 Polynesian Green JMM DEV 3HL/5 kit *sold* EL 5LTR Ghia Argon Silver slammed cruiser *sold* BA UTE daily workhorse ED XR6 Cobalt Blue Project Car |
dont know about that but i do know that an older capri came with a v6 maybe it was the same motor
if some one can shed some light ?
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
Ute Forum Moderator
![]() Join Date: Dec 2004
I remember reading about one, not sure if it was a private import or not though. You are right wodahs, it would have been the Essex V6, ahthough in Germany they would have been built with the Cologne V6 as well.
I know they have granada's(which are basically british cortina's) which had the colonge 2.8 v6. maybe one was imported.
New Project: 1980 MK2 Escort Panel Van, 2lt, auto ![]() Soon to be painted running a 4.0ltr v6 ![]() See the build here http://www.fordforums.com.au/showthread.php?t=11388068 You Have Freedom of Speech Just Choose to Remain Silent |
The South Africans used both the 3.0lt and 2.5lt V6 Essex engines in their TC Cortinas. There was one in a street machine years ago...purple with pink rocker covers (very 70's)
The cologne V6 is a very different motor to the Essex forund in Capris, but some later TE/TF (Mk4&5) Cortinas had 2.3lt colognes fitted with C3 autos in Europe....Mainly wagons. The V6 Essex was available as a conversion through a UK tuner named Jeff Uren. They were badged as a "Savage Cortina." He also did 2.0lt Escorts in the early 70's a few years before Ford got around to it in 1974. Granadas were sold along side the Cortinas in Britain. They were in-btwen the Cortina and Falcon in terms of size, although the Falcon was never sold in Europe. |
Thanks for the info Guys. If I can track one of these or a straight 4.1 litre TE down I'll be a happy man
I remember seeing that TC V6 in a Street machine magazine a few years ago.
The bonnet differed from any other Cortina that I have seen in that the raised centre section is a lot higher than a standard bonnet. Very much in the same way that all Aussie TE and TF Cortina's have a higher centre section to their bonnet than their equivalent MK4 and MK5 brethren thus not needing the TC/TD bulge to clear the air cleaner on the 6 cylinder versions. |
There was also a mk2 cortina with a v6 essex motor in it.
the tc td cortinas also had the same motor as well as imports... I have an escort fitted witha v6 essex in it, it is a tight fit but you should be able to make it fit in the corty alot easier than i got it in the eski. |
The mk2's are the Cortina Savage aren't they.
If anyone has any info on the South African Cortina's could they drop me a line Cheers guys
#10 | |||
They also have a round fuel filler, whereas we have rectangle ones. |
there is a cortina manual not sure which one but is does go into detail about the SAVAGE.
i did read a copie i borrowed about 2 yrs ago off a mate in the car club but he has since moved on. |
#12 | ||
Also forgot to say the raised section on the cortina mentioned i think is from choice and not a factory or needed option as my eski all i have is my airfilter out of the bonnet and only because i chose to and the rest is under bonnet and im running a holley with a high rise manifold too
#13 | ||
The TC and TD Cortina's had the bulge in the bonnet to clear the 6 cylinder rocker cover and air cleaner. The four still had the flat bonnet. All aussie TE and TF's had the raised centre of the bonnet regardless of engine capacity. I'll have to watch my dvd again to see if the english cars had it or not
The savage was a limited run of mk2's fitted with v69's by an english tuner again i'll have to watch my dvd again to get the full story. If anyone knows the whereabouts of the pastel blue VEE 600 NSW rego'd TC v6 that was at Summernats in 92. Could they let me know
#14 | |||
#15 | |||
let it burn
#16 | ||
Steve
There was a SA one in Campbelltown in Sydney about 6 years ago.From memory it was a blue TE shape . The guy had it for sale at a Peter Warren Ford Day in about 2002 .. All I can remember really...
#17 | |||
#18 | ||
These cars are hard to come by, I recall the SA one back in 02 as well, but i haven't been able to get even a pic of one to start my search.
