Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
Performance moderator
![]() Join Date: Feb 2005
With 1200 kg drag car...4000 converter..
With trans brake... How does the trans brake work in conjunction with converter ?? Also with 2 speed [obviously] with 28" tyres what would the ideal rear ratio be... On an 1UZ turbo 4.0 in 1200 kg car... Yes its abit like how long is a piece of string?? I was thinking around 3.45 ratio ?? Being turbocharged.... Never used trans brake..Or auto ...
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 |
Not sure exactly what you mean. If your convereter is the correct one for your combo and it will flash to say 4,000rpm then with the transbrake you should probably use a 3,500rpm limit and let the conveter flash the other 500. So activated transbrake with a 2 step or rpm limiter with 3,500rpm limit relaease the brake (button) and the converter will take up the other 500 and away you go. Oh and hold on!
Not sure of ratio, but it will be determined by your horsepower and how many rpm's you are doing across the line.
383 Clevo, CHI 3V's, solid roller, Glide. 7.97@164.83 mph. |
Yea well ?? It seams turbo's like load and I see Mustangs run real quick with 3:27 / 3:45 ratios and my car is definitely lighter...
With my Falcon 5 speed I'm changing into fourth about 50 meters before finish line..Being 1 to 1 in 4th [126 mph] gearing on a good run and I guess the Celica will be going faster, being auto and much lighter....Close to same power, I hope... So it still runs up on converter ?? Or do you hold it JUST under lock up on two step ? Then hit the trans brake ??? Sheesh much easier than manual and turbo....
Go into full stage, transbrake on, stand on the gas pedal with your rpm limiter on, and thats it.
Ford Power.
the trans brake is activated by engaging reverse at the same time as first gear. it usually works well to use a two step rev limiter thats activated by trans brake button, set the rev limit to around 400 rpm below your convertors max stall speed(as long as you are getting boost in a turbo application) then just hold the button down and hold throttle wide open, engine will stay at your set rev limit and car is held still until you release button, rev limit turns off and trans disengages reverse and takes off forward,, really bloody fast!!!
Craig. |
440cube Dart
Where do you buy the 2 step rev limiter from. As i have a transbrake in my car with a powerglide i was told not to hold it flat to the floor while holding in button. They reckon its better to only hold revs at a certain rev range below the stall rpm. Is this right.
2 step can be part of stand alone ecu or MSD or most ignition systems have them....
I would like to fit one on my Ford ! But its a street car.. Tempting though..... Not easy on cats either.... Two step in action http://rabidz.vidiac.com/video/84ab3...0ab72f82af.htm
#8 | |||
Stay on the transbrake with rpm's up for as short a time as you can. It generates an enourmous amount of heat and will hurt your converter. You can trial what your rpm launch is by just changing the chip in the 2 step. I have a MSD 7AL3 in my car which has a inbuilt 3 step. Depending on what ignition you run will depend on the 2 step.
Ford Power.
thats right, dont use the trans brake with no rev limit on it. it will get very expensive!!you need the rev limit on to keep revs below convertors max stall. around 400rpm works ok but experimenting with that will produce the best launches for you.
Craig. |
#11 | |||
#12 | |||
440cube Dart
So would i better off ditching the crane and go and buy a MSD 7AL2.
#13 | |||
#14 | ||
Most aftermarket ECU's should have 2 step or some sort of launch control...
With turbo engines it sure helps them spool ....
#15 | ||
The convertor has it's own built in rev limiter. If it's built to stall at 4000 then that's about all it will do dependant on the engine's torque. If you want to restrict the start line revs to less than that then use a 2 step limiter.
Holding the revs on the transbrake for a long time is a definite no-no if you want any transmission life. Remember if you trash the clutches, etc in the trans the convertor will need to be split and cleaned also (at the very least). Stage the car (preferably before your opponent until staging is 2nd nature to you), set the transbrake, take it to a few revs above idle and depending on how many lights you have on your side of the tree build the revs as the tree counts. The heat buildup is using a transbrake especially around the 5-6000 rpm mark is massive. With proper care and lessons learnt well it is a great tool for a race car. |
#16 | ||
Its a TCI drag Glide and Domonello 4000 converter
#17 | ||
Being a smaller V8 that doesn't make heaps of torque i'd be inclined to use a rear ratio of 3.9 or shorter, especially with a glide. Also if you Converter is built tight, once you engage the transbrake and rev it the engine will probably have a hard time getting past the 4000 stall anyways. I'd be inclined just to learn how to gradually flash the converter on the 'brake once the yellow's start to flash. Remember these 1UZ's can be revved to 7000+!
What would forum's be without post whoring know it all's......... |
#18 | |||
A few more rpm...
#19 | ||
Our standard Lexus in a BMW drag car we have revved to 8,000rpm without any hiccups. We are using a 3.9 ratio. but will be changing that to a 4.1 or higher with the turbo attached. The smaller engine needs the revs up with the turbo to get the best out of it.
With the trans brake, just stand on the go pedal with the button down when the lights come down. The converter will go up to the stall speed and you will launch with max boost and at the start of the torque curve. Just do not hold it on the limit for more than say 5 seconds as it will boil the fluid. also get the biggest trans cooler possible.
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car BA GT-P for the shed Mustang GT for the other half E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it. BA XR6T for a daily NT Pajero for the bush XB 4 door project- swallows a BF xr6 turbo My dad is a generous bloke. He gave away his dead car batteries free of charge.... |
#20 | ||
Depending on "turbo sizing", they need some load to build boost, just rpm doesn't do much on its own..I have a turbo manual XR 330 Dart block. With the power it makes its E/T isn't that good... It either wheel spins or spool takes place strong at about 3 gear...12.2 / 127 mph.. M/T "radials"..
Torque converters are great things when set up right !!!
#21 | |||
#22 | |||
Would help on turbo selection also...Maybe S400 SX...?? Or twice the $$ GT4202...
