29-01-2008, 10:30 PM | #1 | ||
Over Thinker
a guess
that fuse for the air con should be under the bonnet and thats as much help as I can be it also should run through a relay less than 20 amp fuse the fan motor has a resitor block on it if you cant find the fault... a volt meter will help you
My car goes Brumm Brumm |
