Old 12-06-2007, 05:21 PM   #1
FESTEC
FESTEC's Avatar
Default Bmc Carbon Dynamic Airbox
http://www.bmcairfilters.com/VisModel.asp
I really want a CAI and have been looking around and BMC do the Carbon Dynamic Airbox but it is for the 2.0TDCI model and was wondering will this work on my MK2 Focus... Also what would something like this be worth here in Vic and would revolution race gear be the only one who brings them in.
Also any other that you can think of that is designed for the MK2 Focus??
FESTEC is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 05:26 PM   #2
BlackLS
Posts: n/a
AEM Cold air intake for the Mazda 3 is the go, they have identical engine bays to the LS, check out ozmazdaclub.com in the Mazda 3 section.
Theres a few other cold air intakes avaliable for the Mazda 3, otherwise you can make some up with 3" piping and bents and 3" silicone joiners.
If your like me and have no money, get rid of the second airbox. That will give you intake growl, better responsiveness and a bit of power.
Old 12-06-2007, 05:33 PM   #3
FRA
Mr Focus
FRA's Avatar
i Wouldn't bother looking at that site again.
Get a air intake system like Melbzetec, Simon or myself.
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody
Oz racing: WRC OBX: 4-2-1 race header
SCT: xcal3, dash scan.
FRA is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 06:08 PM   #4
Piotr
Non-Regular Member
The BMC CDA is a universal fit product. They come in 2 sizes under 1600cc and over 1600cc so if you buy an over 2000cc one will be fine. Ive had one in my Fiesta and they are the best. Exensive but really good
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2007, 12:08 AM   #5
melbzetec
Old enough to know better
melbzetec's Avatar
The BMC Dynamic airbox is highly regarded by the FFOC of the UK
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2007, 02:08 PM   #6
Penko13
Penko13's Avatar
Just a quick question guys.
i am running a pod filter as my intake. this means i have taken the top of the air filter box off and just have my pod kinda of above that.
i want to take the hole air box out but i found at the bottom it is connected by some sort of cable and i cant disconnect the cable from the air box. i was just wondering what this is and how i can disconnect it form the air box so i can take it out.
the only thing i can think of it is some sort of an oil breather pipe.
any help would be great
cheers
Penko13 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2007, 06:21 PM   #7
melbzetec
melbzetec's Avatar
If it's an LR, it'll be the crankcase breather line....but it should come off easily
