Hello all.
I own a ford focus st170 with 24.000 on the clock and the car still is under the factory warranty. Last friday I was driving to work and after taking off at the trafic lights the clutch gave up on the 4gear . From first to third, everything was ok, but when I switched to fourth the clutch went hard and started slipping. I managed to take it to a work shop and they adjusted the clutch so I could drive it home. Now I can hear a noise coming from the gearbox that disapears when press on clutch and it is slipping. Is it wear and tear or is it worth it for me to fight for a waranty repair? Thanks nikolis |
#2 | |||
AFF Post NAZI
Focus on my Focus
I would have thought a clutch is a "wear and tear" item. However, it never hurts to ask.
Now: 2006 Ford Focus LX Manual in Satin White Wife: 2013 Kuga Titanium in Frozen White Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way. Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05) American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon |
a clutch is wear and tear but it shouldnt go at 24000km unless youve been giving it a hammering.
#5 | |||
Do I need to relace the flywheel or it can be machined? Last edited by n1kol1s; 06-11-2006 at 09:21 PM. |
at 20,000km or so i need a whole new clutch assembly and flywheel........prolly the way I drive it and the time on the track......
Tried to get ford to cover it but they said normal wear and tear so its not under warranty.......only if its broken but not if its worn out......
03' Imperial Blue Focus ST170 Bluefin Level 2 tune, Custom extractors, Hi-flow cat, K&N panel filter, EBC Turbo rotors with Greenstuff pads. Saving for: cat-back exhaust |
I would preety much guarentee its wear and tear. I know from experience that Subaru dont care at what stage you blow your clutch you have to pay for a new one, its not covered at all. So god knows what fords stance on the issue is.
Its one of those very grey areas. IF its really faulty, as in a manufacturing fault then they will replace it for nothing. But good luck proving it. But like photn said, fight your **** off before you give in. |
#8 | |||
Zoom Zoom
2012 Mazda3 MPS
#9 | |||
Is there a heavy duty clutch kit out there for the st170?? |
#10 | |||
Candy White GTI
I think the noises might incidate the clutch or gearbox is damaged or broken. If i were you i would ring ford and say the cars gearbox has been making funny noises over the past few days and you are concerned... then tommorow ring back and say your wife was driving it to the shopping centre when you recieved a phone call saying the car had broken down and refused to go into gear properly and refused to move. it felt as though it had no clutch and was making a weird ticking noise. See if they can refuse that ![]()
Volkswagen GTI Polo. Candy White, Anthracite heated Sports leather seats w/ Red stitching.Tinted Windows, Eibach Pro-Kit springs,Whiteline Front/Rear adjustable sway bars,Cupra R intake, Forge Turbo Inlet pipe,BMC panel filter, APR stage one flash, Dunlop SP sport MAXX, Forge Polished upper front strut brace. 3'' downpipe and highflow cat Loads of fun ![]() |
Old enough to know better
Come on N1kol1s, you've already said you give it a hammering, and you were giving it a hammering when it went, so fair's fair.
It will be a wear and tear item guaranteed. Here is a starting point for heavy duty clutches for ST170 (or SVT in the U.S.) http://www.focussport.com/clutch.htm http://www.newedgeperformance.com/in...ROD&ProdID=290 The info I've seen from the states says the stock clutch is fine even for big turbo power upgrades, but you'll toast it if you do burnouts. Think about it.
