Old 23-02-2012, 09:40 PM   #1
4vxc
Default who uses a trans brake?
I use a FMX but have been offered to try out a transbrake equipped c4 to see if I like it. The question is what drop in 60' times and 1/4 mile ET have you seen using a trans brake compared to a normal stalled up launch.
4vxc is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2012, 07:25 AM   #2
GTP owner
GTP owner's Avatar
Default Re: who uses a trans brake?
it all depends on grip, tyres used, stall speed, power, brakes, etc etc. A street car with close to stock power will not make much difference. In a high horsepower drag car with slicks and littlies up front will drop a second or two off the time.
For example - a street car on street tyres will just blow the tyres off with a trans brake, so making it slower or exactly the same.
My xa coupe can't hold the power and the grip from the rear tyres without the trans brake, so i drop over half a second using one.
So give us some more details of what you want to run it in and we help give you and idea of the difference
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car
BA GT-P for the shed
Mustang GT for the other half
E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it.
BA XR6T for a daily
NT Pajero for the bush
XB 4 door project- swallows a BF xr6 turbo
My dad is a generous bloke. He gave away his dead car batteries free of charge....
GTP owner is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2012, 09:59 AM   #3
prasac
prasac's Avatar
you'd pick up a couple tenths ET for sure.
as GTP Owner said more details would help.
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2012, 11:49 AM   #4
GASXR6
GASXR6's Avatar
Basically, if your car is setup to run the 1/4 mile and you already have the correct converter it won't change your times!!!! It is basically for consistancy as you leave at the exact same rpm's every single pass! If you're changing from fmx to c4 you will see some change one way or the other. I used a c4 for quite a while with no brake then went to it and picked up hundredths.
383 Clevo, CHI 3V's, solid roller, Glide. 7.97@164.83 mph.
GASXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2012, 04:38 PM   #5
GTP owner
GTP owner's Avatar
If you can't hold the car on the brake, then it WILL improve the times if you have traction
BA XR6T for a daily
Old 01-03-2012, 09:24 AM   #6
Starlightblue
Starlightblue's Avatar
I use a trans brake and absolutelly love it. Just makes it so easy to get revs right and test with alot more certainty of what changes you are making.
Im running a 1.5 60 foot
highly recomend transbrake
Starlightblue is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2012, 10:21 AM   #7
xagsjoe
Patience is a virtue
xagsjoe's Avatar
Best 60 without it is 1.42 and 1.38 off the brake and a 2 step. You really need the 2step with a transbrake to get the consistancy out of it.
417ci CHI headed XD.
Dynamic transmissions C4
Track times
60ft pb 1.365 (24-3-12)
10.173 @ 134.97mph 1/4
6.324 @ 108.93mph 1/8th PB
SOLD
xagsjoe is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2012, 11:37 AM   #8
Starlightblue
Agreed Also Using 2 Stage
Old 01-03-2012, 12:39 PM   #9
jcxr
Tribal Elder
jcxr's Avatar
Whats involved in setting up?
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2012, 07:05 PM   #10
GTP owner
GTP owner's Avatar
its a kit that needs the trans to be pulled apart and rebuilt with the solenoid built in. They are specific to the trans you have (ie you can't use a generic kit). The major speed suppliers have them
BA XR6T for a daily
Old 01-03-2012, 11:21 PM   #11
ebxr8240
Performance moderator
ebxr8240's Avatar
EB 6 on Boost with forged turbo motor just kills the C4 ''
10.5 X 28 slicks...
Going Powerglide, aftermarket case etc..
He was holding fairly high rpm and boost..
Two rebuilds in short time he gave it away..
550+ RWKW with decent torque kills them..
Dominello wouldn't fit a trans brake on Jamie's Fairmont due
to strength issues..
Should be o/k on lighter car such as Cortina..
Daily driver GTE FG..
Old 03-03-2012, 02:16 PM   #12
Rural 351
1000+ passes
Rural 351's Avatar
I tried a trans brake in my high 9 second capri in the 90s it didn't have tubs and was on the limit of traction, I found it was slower since I couldn't load up the suspension and the weight transfer wasn't as good as holding it on brakes and making the noise dip down, It hit pretty hard make sure you have good axles, I'm sure with heaps of traction it would be great,
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph
https://www.facebook.com/DragRacingT...2067110055900/
http://www.cacklingpipes.com/100825_...250810_025.JPG
XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph
The faster youve gone the worse your attitude
Rural 351 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2012, 05:03 PM   #13
SSD-85
Are Transbrakes allowed on public roads...? Sorry, just curious.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2012, 06:27 PM   #14
proesc
proesc's Avatar
yes, they dont engage unless you activate with a push button on the wheel or shifter.
proesc is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2012, 09:56 PM   #15
prasac
prasac's Avatar
you can get a switch to turn it on n off also, just so you can't accidentally hit it. the transbrake only works it first gear, it won't lock in any other gear.
Thread Tools
Display Modes
