#751 | |||
Sorry I was distracted by all the egregious amounts of cash I am making updating everyone maps.
testerPresent Diagnostics & Software | Github Profile Jakka351 | Fg Falcon Git Repo | email:jakka351@outlook.com |
#752 | |||
You can't say something like that to someone who has been here since 2005!
#753 | ||
#754 | |||
#755 | ||
Away on leave
There are so many issues with that, and yet I'm as close as anyone will get...
https://github.com/varghes/Raspberry-QNX You can see, I opened an issue there, and I've fixed a bunch of stuff he didn't quite have working properly. This version of QNX (6.5) runs on a Pi Zero W (almost the same CPU as the FG2 ICC) which is 1GHz instead of 666MHz - so it's got a bit of a speed bump on the old ICC's CPU. It's still too slow though. I have the SD card, USB keyboard and mouse, HDMI audio all working along with the QNX Flash Lite 3.1 media player. It's pretty cool, and boots in a matter of seconds into my layerlaunch & layer (v3) programs from my earlier post. A neat toy, for the couple of Pi Zeros I had lying around doing.. not much. But, you see, this is the old ARMv6 QNX for single core CPU boards. For any recent Pi greater than a zero, you need at least a QNX v7 version... And I can't find an old one anywhere. I can't find a new one either, but once you start using a newer one, you need to use the newer GCC compiler too, and then you lose compatibility with the old ICC software & libs. So many issues ![]() |
#756 | |||
#757 | ||
Away on leave
I think I messed up what version we're talking about. I meant to write QNX (6.5 sp1) for ARMv7 (which I think would work on a Pi2 or Pi3) should support multi core units, and is certainly enough to do some neat stuff. This kernel would not run on a RPi4 though, it's just too different.
Actual QNX 7.0 is known to have a BSP (support package) for RPi4, but nothing lower. There's sure to be issues with that because the GCC version used to build it would be so much newer. I'm already seeing some issues with recent Linux software being compiled on the 14 year old GCC I'm using for what I make for my ICC & the Pi Zero. Either way, I'd say the simple answer is no. |
#758 | ||
Says someone posting from a pseudonym. I can't post your real name, but you can.
#759 | |||
#760 | ||
Fossil fuel consumer
![]() Join Date: Jul 2005
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Just keep the arguing to a low roar if we could. Back on topic.
#761 | ||
For the record though. My names not Jack.
Its Benjamin. On topic again: ![]()
#762 | ||
Away on leave
FG MK2 High Series Navi Map Updater
This package backs-up your current maps into a folder it creates on the thumbdrive called "oldcontent" when you run it with no new maps (a freshly formatted FAT32 USB stick, with just the expanded archive on it). If you have new maps (*.fbl, *.poi or *.spc [btw it doesn't allow filenames with spaces]) in the thumbdrive root, it attempts to patch your navi exe to remove the license check. It will tell you if it can or can't do it to the version installed. It's been tested on a couple of versions, early 2013 and mid 2014. Then it makes a backup of the maps (as before) and copies new maps over. It reboots if it works (it terminates the navi software to update it, so the reboot is needed to restart it all up again). It uses the USB root as a working area, so there will be files left there once it's done... New and old versions of the exe and various original manifests it updates on the unit. Run this package with the Recore button in FG2ICCComms.exe using a ELM327 with HS/MS switch on MS. https://github.com/Jasoroony/Ford-Fa...n/navimaps.zip I usually buy the map update file(s) by using my Android phone with the iGo software, then get the .fbl file from it using a USB cable to plug the phone into the computer to browse for files. This time (new Aus maps were released a couple of weeks ago - 2021Q4) I found a download that had maps, places and speedcam. Sadly the speedcam file didn't load properly, so I went back to the 2019 file that I bought from China. The update is a slow process, backing up 200MB takes a long time, copying back 200MB also takes ages, patching the exe isn't particularly fast either. Keep the car key on accessories while it works, you don't want the unit going to sleep in the middle of an update. If you have updated your ICC maps from elsewhere, this process may not (or may?) work... Sorry, but I can't help you if it doesn't - I don't know anything about how that update was made to work. |
#763 | ||
Anyone interested in their Fords GPS module, can take a look at this git repo - https://github.com/schoolpost/ford-gps-module I dont think that the falcons broadcast their GPS data on the CAN, but other models probably do.
be good for a DIY gps tracker or logger, or for your insurance company in event of accident.
#764 | |||
#766 | |||
Wut dis do JasonACT?
#767 | ||
Away on leave
I give up, what does it do, Benjamin?
#768 | ||
"\"V01.16.rel\""
"\"ssssssssssstssssssssssutsssssssssvutsssssss swvu tsssssssxwvusssssssxwvuttsssssyxwvuttssssyxwwvuuts ssyxxwvvuuttsyyxwwvvuuttzyxxwwvvuutzyyxxwwvvuuzzyx xwwwvvv{zyyxxxwwvv{zzyyxxxwww{{zzyyxxxxw|{zzyyyyxx x|{{zzyyyyyx\"" "\"IICA_HandleErrorCh0_Tsk\"" "\"IICA__AlarmCh0\"" <----- Annoying Chime "\"IOQHA_vQhandle_Tsk\"" <!----Annoying Chime "\"SINI_vInit_Tsk\"" <!----Prepare Annoying Chime "\"SOUND__vMain_Tsk\"" <!----Annoying Chime "\"SOUND__vMain_Tsk_Alarm\"" <!----Annoying Chime "\"STATE_vStateHandler_Tsk\"" <!----Annoying Chime Current State "\"RES_SCHEDULER\"" <--- When Should The Annoying Chime go off "\"VOL_vProcess_Alarm\"" <!----Annoying Chime "\"VOL_vProcess_Tsk\"" <!----Annoying Chime "\"EEPB_vHandleTransmission_Tsk\"" <!----Annoying Chime when the gearbox fails "\"EEPB_WriteCycleTimer\"" <!----EEPROM Write Access Timer? for the Annoying Chime "\"FUEL_vSampleSender_Tsk\"" <!----Annoying Chime when I dont have a fuel level signal "\"FUEL_vSampleSender_Alarm\"" <!--- same as above "\"CAM_Alarm\"" <-----Annoying Chime but unsure what for "\"CAM_vForegroundLoop_Tsk\"" <!----Annoying Chime Program "\"LCD_Access\"" <!----Annoying Popup to complement Annoying Chime
testerPresent Diagnostics & Software | Github Profile Jakka351 | Fg Falcon Git Repo | email:jakka351@outlook.com Last edited by jakka351; 09-08-2022 at 05:07 PM. Reason: My names not Benjamin, its Jack Whiteford |
#769 | ||
been reading the posts
but i have a question has anyone got any info to share on how to fix the orignal units i am trying to help someone out atm thanks |
#770 | ||
The info is in said posts.
#771 | ||
Away on leave
#772 | ||
#773 | |||
#774 | ||
#775 | |||
https://www.aliexpress.com/item/3300...8dawia2cW&mp=1 Or https://www.aliexpress.com/item/3232...8dawia2cW&mp=1 When messing around with the MK2 ICC's a few years back, I did try swapping a screen from a working unit into a another which was no good (The actual physical LCD) and it did light up. So... Id assume its the actual LCD screen which is failing and not the circuit board its attached to. Guess its an option for anyone game enough to try a cheaper alternative. |
#776 | |||
#777 | ||
Didn’t realise the MK1 FDIM would work in place, that’s kinda incredible to be honest!
#778 | ||
MK1 colour screen is bulletproof too.
Haven't seen or heard one fail. I have both in case my MK1 colour screen fails ![]() Do you give discount to ford forum members? ![]() |
#779 | |||
Guess I was one of the rare ones then, since I used the actual LCD and not the FDIM circuit board. Be interested to hear if anyone else tried out a screen only change. |
#780 | |||
Mate is that software you're using available to a novice like me? I'm really keen to be able to switch a fg mk1 fdim from dual zone to single zone. I was hoping it was going to be something I could do in forscan but that doesn't seem to be the case. |
Thread Tools | |
Display Modes | |
