Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Early Falcon Car Club of Qld Inc
Early Falcon Car Club of Qld Inc The Queensland early model Falcon Club.
Old 23-08-2008, 08:51 AM   #1
charles bronson
Default WHY!! XP - collapsible steering column with V8?
Hi people. How come I am told that I have to change my original XP steering column to collapsible yet I am spotting V8 XP's everywhere around here (in QLD) still with the orig column. I understand if the engine is a 289 or under then you dont have to change the column. Yet you need to make alot more changes to your car if it exceeds that engine size.
Seatbelts, the wheel pattern changed to be 5stud and discs (only on front) front needs upgrades such as stronger springs. I have even been told I need to change the colour of my front indicator lights to red..
I have a 302 Windsor and live in QLD. Does it just come down to certain engineers being more (shall I say) casual about the regulations? Or is everyone simply lying about there engine sizes. Easily done I guess as they made Windsor engines for over 20 years and 289 and 302 being so physically similar.
Any contacts or info would be great. My question. How are people getting around not changing the steering column? Thanks heaps.
charles bronson is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2008, 01:12 PM   #2
xwboss
xwboss's Avatar
I will be talking to a QLD Early Falcon club member tomorrow who is the most recent member to fit and register a V8 (302) in an early car.
I will let you know what he had to do and who he used
Territory black VSI lpg
XW GS Fairmont 351C toploader 9inch
Mazda Bravo 4 X 4
xwboss is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2008, 04:25 PM   #3
charles bronson
Nice - cheers. The car is 100% done and I have been holding off getting it certified as I dont want to make the steering column alterations. As I see so many XP's/302 around with the orig steering column and think why should I... Thanks mate.
Old 24-08-2008, 04:09 PM   #4
fat289
fat289
fat289's Avatar
The rules change , maybe the cars you have seen have been registered for some time now !!!!!!!
If you don't change it - NO rego , fairly simple !!!!!
I'm just having a great Falcon time , thanks for asking dumba$$
XRGT
XP ute 351w Toploader
99 Springer softail
XW Fairmont 302w / c4 col shift 58,000 miles
fat289 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2008, 07:12 PM   #5
xwboss
xwboss's Avatar
Talked to a mate today who recently went through this and yes he had to put a collapsable column in which is a bit of a job.
I will PM you with some people you might want to contact.
Mazda Bravo 4 X 4
Old 21-11-2008, 03:41 AM   #6
stephane
screff_au
stephane's Avatar
trying to convert my wagon at the moment and had same problem anything bigger than 289 and qld rta wants collapsable column, lucky for me i am fitting 289 in but hey in the end you cant tell from outside if its 289, only give away is cast number anything starting with c8 ie 1968 and your starting to run into 302, 289 stopped been built after 1968( give or take a few months). good luke i haven't even started mine its all on paper at the moment, but working with good mech who hasn't steared me wrong yet.
stephane is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2009, 03:55 AM   #7
vicki34351
Cool How did you go with the collapsible steering column?
How did you get on with the collapsible steering column. I currently am in the same situation I have an XP and just fitted a 302 and must replace original column for engineer and registration.
Not sure what I can replace it with!
Regards,
Vicki34351
vicki34351 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2013, 10:13 PM   #8
xwsarebset
Default Re: WHY!! XP - collapsible steering column with V8?
I have in the past done xrs and xts using an xw xy column very easy to fit, you can then put xr xt coffee pot etc on xw xy column and install your original indicator switch assembly and steering wheel take an expert to pick and no structural integrety modications to steering assembly. I also done this to my compact fairlane i had over twenty years ago. I am unable to remember if the xk to xps have flex link on the steering box the same as the compact fairlanes and xw xy or solid shaft same as xr xt.
when working on these old girls it is amazing what parts are completely interchangeable,without any structural changes to parts just mix and match.
If you are worried about coloured lenses no reson why you cannot do what the new car manufacturers do and fit orange or red coloured bulbs behind the clear lenses. if you cant then that would make a lot of new cars unregisterable off the showroom floor.
I always say look and measure the size of the beast before you butcher it.
Last edited by xwsarebset; 14-01-2013 at 10:27 PM. Reason: added extra information about coloured lights
xwsarebset is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2013, 10:40 PM   #9
gravelrash
Fit a 302, tell em it's a 289..or fit a 289 and put a 347 crank in it..
Was 250 2v turbo XP falcon.....now fuel injected turbo crossflow XP falcon..412hp at the tyres, Yeah baby..
gravelrash is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2013, 11:18 PM   #10
xwsarebset
You can put in orange bulbs on front indicators but no RED lenses on front of vehicles as red designates braking and taillights. only emergency vehicles and police can have forward facing red lights or lenses.
That is why guide posts have red reflectors on one side of the road and white on the other so you know which side of the road your on.
The mounting holes for the seat belts may be there from factory as this was an option on early fords.
Old 22-12-2013, 08:24 AM   #11
'63Deluxe
Irregular Member
'63Deluxe's Avatar
Gold! I have been wondering how to use my original steering wheel
The search begins for a xt coffee pot...
'63Deluxe is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2014, 12:13 AM   #12
choppmyride
I have just done a collapable collum for a XP Squire , used a XW colloum with XP top end of colloum , auto gear change , all works fine
Leon
choppmyride is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2014, 08:14 PM   #13
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
Leon
Chopp,
Time for a build thread for your Squire......
Mel Brooks sums it up best;
"Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut"
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2015, 09:41 PM   #14
662DXP
662DXP's Avatar
302 going into my coupe. Engineer requires collapsible steering column to be fitted.
I have fitted a Xe column coupled to the original steering box.
Plenty more pictures of the fitment back on page 14 of my thread click on the link below.
Cheers Darryl.
66 Xp 2 door project
http://www.fordforums.com.au/showthread.php?t=11357717
662DXP is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2016, 01:11 PM   #15
skr8pn
Do any of you guys that have had to change to a collapsible have the original auto column?
Thanks
skr8pn is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2016, 09:19 PM   #16
marxy
marxy's Avatar
I have an xp 3 speed auto column I might sell for the right price!
marxy is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2016, 09:48 PM   #17
skr8pn
Wink Re: WHY!! XP - collapsible steering column with V8?
I need the linkages also. I want to change from manual.
Old 05-04-2016, 10:10 PM   #18
marxy
marxy's Avatar
I will send you a pm, cheers
Old 06-04-2016, 05:28 AM   #19
skr8pn
No worries
Old 08-04-2016, 05:57 AM   #20
Interceptor
HSV - I just ate one!
Interceptor's Avatar
what I really dont understand is why people are up in arms about what is basically a safety measure....
Interceptor is offline   Reply With Quote Multi-Quote with this Post
