Closed Thread
Old 04-06-2015, 10:29 AM   #241
Smoke Pursuit
Default Re: New Aurion Presara $50,490 !!!!
Originally Posted by zilo View Post
An indicator of your lacklustre income.
My wife's AMG optioned Mercedes does 100 when the speedo indicates 100.
Cool story bro.... I have one of those AMG optioned Mercedes too... Big *** deal!
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline
Old 04-06-2015, 10:30 AM   #242
Polyal
The 'Stihl' Man
Polyal's Avatar
Yes because there is zero tolerance with the calibration of the speedo, the GPS your checking and the police radar detector.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Polyal is offline
Old 04-06-2015, 11:47 AM   #243
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
The Pajero I used to have was on average 8km/h slower than the indicated speed pending tyre inflation so I used to always sit on 5km/h over the indicated limit to keep up with traffic.
Fairly certain the wife's Lancer is about 2-3km/h out which I can live with.
Carless
TheSneakiness is offline
Old 04-06-2015, 11:58 AM   #244
Express
Bathed In A Yellow Glow
Express's Avatar
Strange that a Mercedes with some AMG options is 100 at 100.
On the AMG Lounge (Forum) the owners of genuine AMG’s report their car’s actual speed is 97 when reading 100.
I just see on MBWorld where they have shown a speed delimited C63 with a speedo reading 312km/h and the GPS reading 302km/h.
Express is offline
Old 04-06-2015, 12:07 PM   #245
Franco Cozzo
Franco Cozzo's Avatar
Who here has a GPS and a Bluetooth OBDII module?
Check the speedo needle vs OBDII speed reading vs GPS.
I reckon the OBD readout will be closer to the GPS than the needle, within 1kmh or so.
Franco Cozzo is offline
Old 04-06-2015, 12:29 PM   #246
Sabantien
According to the GPS i my car my G6E is 3k out. That could be from having the xr6 tyres on the back, not sure how much the slight size difference makes.
According to a truckie I know the speed limited trucks are bang on 100, so if I judge it off that, my speedo is about 50k off.
Sabantien is offline
Old 04-06-2015, 01:49 PM   #247
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Lol, Perhaps you could spend some of your income on an Insurance Broker...
BENT_8 is offline
Old 04-06-2015, 02:21 PM   #248
Matty4
Banana
Matty4's Avatar
Wow.......so now the personal attacks come out over a Toyota???.......
FFS...........some people need to grow up!
2024 Ford Ranger Wildtrak V6 w/PP
2012 WK2 Jeep Grand Cherokee Overland CRD
Matty4 is offline
Old 04-06-2015, 02:26 PM   #249
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Sorry Officer, just some harmless banter.
BENT_8 is offline
Old 04-06-2015, 03:25 PM   #250
2242100
Originally Posted by Express View Post
I’m surprised.
Am I reading this right, are you saying a stock XR6T is capable of a 4.56 sec 0-100?
What are the grip issues you’re talking about and what numbers do they actually make in everyday driving?
When in sports mode my Merc goes like a scalded cat from a standing start in first gear, no second gear start needed.
It reverts to second gear take offs only when in placed in comfort mode.
Yes that's correct and it was measured by the same accurate GPS based equipment the Magazines use. It performs well under widely varied weather conditions (including very hot temperatures and high altitude) as can be seen from the 3 runs below.
All runs at over 650 metres altitude (that typically slows acceleration by about 3% to 4%) on a surface with very good, but not special grip (less than a well prepared Drag Strip).
Run 1) Conditions:- 90 kg driver with a fair weight at the back of the car. Ie full sized spare plus jack, tools etc and almost a full tank. Car total weight approx 10 kg's above what it would be with just a full fuel load. 2200 RPM stall, temperature cool at 14 degrees.
Run 2) The car was about 10 kg's heavier than on run 1. Stall up again over 2000 RPM and temperature was 25 degrees.
Run 3) Practically the same 10 kg heavier load as RUN 2, but the big difference was in the temperature.
It was a sweltering 39 degrees and stall up revs were lower at about 1800 RPM. For that reason I'm also listing 20 to 100 km/h times because the 0-20 time of this run isn't comparable to the others, due to the lower stall revs. The car launches harder just above 2000 revs.
RUN 1..............................RUN 2.............................RUN 3
Temp...14 degrees ............Temp...25 degrees.............Temp...39 degrees
0-20.....0.64 sec.................0-20.....0.63 sec...............0.83 sec
0-40.....1.41......................0-40.....1.45.....................1.67
0-60.....2.24 @ 20.03 M.......0-60.....2.27 @ 20.34 M......2.52 @ 21.21 M
0-80.....3.38......................0-80.....3.41.....................3.72
0-100k..4.56 @ 71.67 M.......0-100...4.64 @ 73.37 M......4.95 @ 75.55 Metres
20-100 Km/h 3.92 sec.........20-100 4.01 sec.................20-100 4.12 sec
So the car was only 4.85 % faster with a 25 degree temperature advantage in this case, I was very happy with that. Fast at high altitude and in high temperature situations.
Certainly grip can be a real issue with a lightly loaded car on low grip worn surfaces that can be found at intersections. That's where the second gear launch can be useful, the car accelerates quickly over a wide speed range without having a particularly high (brief) acceleration rate that's likely to cause traction loss.
I'm not surprised that you're surprised by my numbers, but people generally think of FG Turbo's as having 270 kW/533 Nm, whereas in everyday real world situations far more power/torque is available (there is the overboost and 98 fuel gives my car 10% better pace than the 91 that they can run on).
Mines no freak, others on the NET (including the XR6TURBO.COM forum) have performed like mine, I just happen to have the accurate GPS based timing gear (and I'm nerdy enough) to measure the performance.
I haven't seen a time that seems fast from an FGX yet, I'm wondering if they have the overboost feature in their tune.
Not sure what model of MERC that you've got. but I'm suspecting it might have a better rear wheel tyre combination than my standard tyres and wheels.
2242100 is offline
Old 04-06-2015, 04:35 PM   #251
zilo
BANNED
zilo's Avatar
In a canbus system the instrument cluster and the OBD data will be identical.
zilo is offline
Old 04-06-2015, 04:40 PM   #252
MAD
Petro-sexual
MAD's Avatar
Yes, but the conversion of digital data to an analogue needle loses some accuracy.
I can bring up a digital readout of my speedo in the EL, and it varies in its relativity to the needle at different speeds.
EL Fairmont Ghia - Manual - Supercharged
- The Story
MAD is offline
Old 04-06-2015, 06:00 PM   #253
malazn mafia
Boss 335
malazn mafia's Avatar
EL never ran canbus, as it was electrically an evolved EA. BA/Territory were the first to use canbus.
malazn mafia is offline
Old 04-06-2015, 07:55 PM   #254
MAD
Petro-sexual
MAD's Avatar
Obviously, but the digital to analogue conversion is still the same. Just a different way to access the data.
- The Story
MAD is offline
Old 04-06-2015, 09:10 PM   #255
Bossxr8
Peter Car
Bossxr8's Avatar
Originally Posted by EASYBOSS View Post
Hulk is not the OP
He turned the thread to rubbish though, as always.
Bossxr8 is offline
Old 04-06-2015, 10:36 PM   #256
zilo
BANNED
zilo's Avatar
No it isn't.
zilo is offline
Old 04-06-2015, 11:31 PM   #257
AU1XLS
AU1XLS's Avatar
Closed
AU1XLS is offline
Closed Thread
