Old 26-10-2011, 02:45 PM   #1
ACCC
Default Don’t be a jackass with jacks during DIY car work
Getting under a car that is only supported by a jack can be fatal. Nearly 50 Aussies have been crushed or killed over the last decade from getting under a vehicle that wasn’t properly supported. And over 160 Aussies are injured each year with amputations, fractures and crush injuries from not using a jack properly.
If you do your own repairs, avoid becoming one of these 160 Aussies injured or killed. Learn what you need to know to DIY safely in several easy steps.
Stay safe while caring for the car you love…
Make safe - buy safe - use safe
A product safety message from the ACCC
productsafety.gov.au
recalls.gov.au
accc.gov.au
ACCC is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2011, 03:54 PM   #2
Fev
Fev's Avatar
Default Re: Don’t be a jackass with jacks during DIY car work
Entered! Tis bad, i've seen some dodgy ways of lifting cars. Always makes the heart skip a beat
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2011, 06:11 PM   #3
XESP351
XESP351's Avatar
I just changed the brake pads on the ute, and even though the front was on stands, the jack at the ready, and both wheels flat under the car, I was still nervous getting underneath it. I think I have a phobia lol.
XESP351 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2011, 06:32 PM   #4
mik
mik's Avatar
great to see a bit of a safety message for something that at some stage just about every driver would be faced with.
i had to go and change a neighbors wheel a week or two ago, the young girl did`nt have a clue how to change a wheel and just drove it home flat, pity it`s not a part of getting your licence.
Old 26-10-2011, 06:46 PM   #5
Giant Cranium
PURSUIT 250
Giant Cranium's Avatar
already a old thread on it
http://www.fordforums.com.au/showthr...hlight=jackass
Giant Cranium is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2011, 06:50 PM   #6
Jim Goose
mik couldnt agree more... as part of licencing it should be made part of the test hat you know how to change a tyre "safely", or at the very least its part of the driver training and ticked off in the logbook by the instructor.
I always go a bit overboard now when working under a car due to a close encounter i had in my shed a few yrs ago.
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2011, 07:40 PM   #7
NAK302
NAK302's Avatar
http://www.smh.com.au/travel/blogs/t...503-1e6hf.html
NAK302 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2011, 08:47 PM   #8
asdf1234
Errrr.. I jack it up and put a brick somewhere is that safe enough?
asdf1234 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2011, 08:53 PM   #9
FAT245
Lacking Imagination
FAT245's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Nath deserve's a Technical Contributor award for his willingness to share everything in his vast knowledge of tuning EEC-IV and -V Falcons, not to mention engines!
guys across the road.. were trying to balance the car on a jack while removing the IRS Diff from their VT Sedan...
i took em a few jackstands to save me the hassle of needing to deal with the police
My 11 Second AU Fairlane
364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W
FAT245 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 11:41 AM   #10
Hulsty
No, bricks,rocks etc are brittle and can crush/shatter etc. At least use a solid block of wood.
The Silver Bullet - BJ74
Where the actions at Ontrack 4wd Club
https://www.facebook.com/ontrack4wdclub
Hulsty is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 12:51 PM   #11
AndrewR_AUII
AndrewR_AUII's Avatar
Those who participate at Motorsport events: This is something that is being watched. Stands are another item to add to your kit.
Also be aware of the surface that you are working on... earth/grass will move pretty easily - Bitumen actually can as well under enough pressure (eg if the weight is over a small area).
AndrewR_AUII is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 01:43 PM   #12
jrfttf
Getting By!?
jrfttf's Avatar
Couldn't agree more with it been part of your license ect, knowing the basics.
Agree with the bitumen sinking as it has happened to me, another pet hate of mine is scissor jacks. Absolutely hate the things!
Big beleiver in jackstands myself as i have had a relative been under a car and the jack was leaking which near led to a disaster.
jrfttf is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 01:50 PM   #13
2011G6E
2011G6E's Avatar
I use a couple of old chrome 12-slotters underneath any car I'm working on (or the spare wheel of the car if I'm changing a tyre), or my "favorite lump of wood", a piece of stump about 20 cm in diameter and 40cm long, hardwood.
Yesterday coming out on the highway from Rocky, I saw a guy underneath a big camper trailer behind a car, one wheel off, just a jack holding it up, as he heaved away on something near the springs as his missus watched on.
At least there was someone there to phone for emergency services if it gave way and caved his skull in...
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 04:08 PM   #14
tankclare
BURN RUBBER NOT OIL
tankclare's Avatar
I get a bit paranoid myself. Even went out and got one of those big trolley jacks thats rated to 2 tonnes I think it is. I feel safer changing tyres and small jobs with that instead of a crappy scissor jack or little trolley jack everyone has. When doing bigger jobs like pulling a diff apart etc I always use stands or at least some wheels to support the weight of the car.
[TUFF4L] EF Fairmont Ghia build thread - http://www.fordforums.com.au/showthread.php?t=11381891&highlight=tuff4l
[SMOKES] FG XR6 build thread - http://www.fordforums.com.au/showthread.php?p=4795218#post4795218
tankclare is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 04:59 PM   #15
Franco Cozzo
Franco Cozzo's Avatar
I've got a new jack and 6 new jack stands, two big 7800kg ones (they're 780mm high so could come in handy if I need the car raised high)
Safety first, I'm not getting under a car unless its resting on stands.
Old 27-10-2011, 06:51 PM   #16
asdf1234
Where should I put a block of wood then? What if wheels are off?
Old 30-10-2011, 01:23 PM   #17
Blue Oval Mopar Man
Has Blue Blood
Blue Oval Mopar Man's Avatar
Bad....VERY BAD , Bricks have a tendency to crack and break letting the car fall.
No joke, Ive seen it many times . Timber is much better , but only a hard wood should be used if nothing else is available. And never put a metal edge along the grain of the timber , always across it !
Decent quality jack stands are a much better option .
Real cars dont wear bowties
I'm not arrogent , Just superior
Blue Oval Mopar Man is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2011, 12:56 PM   #18
Mozz
Another supporter of proper jack stands, our cars aren't featherweight.
Mozz is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2011, 01:20 PM   #19
dawsman
FG GT 335 Owner
dawsman's Avatar
I only feel 100% safe under a car when using ramps, but this really isn't possible with low cars and/or body kits (front spoiler, skirts etc.). Also no good if the wheels need to come off.
I know someone with a couple of hoists which often comes in handy.
TOY: 2011 FG GT 335 #0498, Nitro, 6sp MANUAL, 18% tint, Herrod K&N Filter, Herrod-JLT oil breather, Manta twin 3" s/s cat-back exhaust, Shockworks adjustable coilovers, R-Spec wheels (build thread)
DAILY: 2015 PXII Ranger Wildtrak, Pride Orange, 6sp auto, tech pack (pics here)
BEFORE: 2005 Mercury Silver BF XR8 ZF Auto, 20% tint, custom 2.5" cat-back exhaust, Advanti Zeta 19" wheels (found it!)
dawsman is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2011, 03:04 PM   #20
fordman302
fordman302's Avatar
I was lucky enough to have this one drummed into my head from a young age, a result of my fathers mate being killed by one of the old fassion hydraulic hoists back in the day, before i go under my car i try to push it off the stands if it stays i am happy to get under, and if if it comes off...... hmm well i havent had to deal with that one yet
fordman302 is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2011, 04:32 PM   #21
Transit Truck
Transit Truck's Avatar
Or stack some pallets under the car.
Transit Truck is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2011, 06:01 PM   #22
Neale
Neale's Avatar
one thing I remember hearing about was a guy that was jacking his car up in the garage with the small based factory jack.
When he was doing this the jack went through the concrete floor because the concreter that layed the slab used foam blocks in the concrete to make it go further.
A common practice for modern homes but should not have been done for the garage floor as the concrete was not thick enough to support the weight of the car while it was on the jack.
Its a freak accident but also a good reminder to use jack stands or some of the other suggestions that people have said.
Neale is offline   Reply With Quote Multi-Quote with this Post
