rexnet
so mine has a leak. which obviously is quite bad. because i thought i'd just have a look at it this morning and there was no fluid in there (oh damn)
so i put some fluid in there but the following questions . 1. does this mean my rack is also dead because its been out of fluid for X long. 2. is it worth getting one from a wrecker/2nd hand. 3. is brand new the only way to go. thanks. |
Flairs - Truckers Delight
1. I highly doubt it
2. fine if you're selling it 3. See q2 also, are you sure it's the pump and not one of the hoses?
#3 | |||
rexnet
i shall go investigate. thank you. |
rexnet
i had a look. and took a photo. its all tight. the leak/gush/weep seems to be coming from the lower bolt.
that being said. the above bolt is a bracket which i dont have attached to anything because i have extractors. and it lost its mount point (or i lost the bolt haha) and it was a bit loose. does this effect the seal of the pump res? ![]() |
Smile
Yes I was told by a power steering place my pump hoses needed changing for a few hundred dollars. I discovered that all it was is a rubber o ring that seals where the the tup of the hose alloy coupling seals against the pump. The oring cost me 3 dollars two years back. It looks like this is the likely cause
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
rexnet
You have made my day. Thank you =]
i had the same problem it was a leaking top hose which leaked in to alternator causing it to fail as well. it is a common fault with the hose
Critical Thinker
Another vote for the o-ring. I had mine done recently. Happens after a while on AU's. Forgot how much it cost to fix mine, but it wasnt all that much. Had the p/s unit resprayed black while it was out.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
rexnet
Well I went to ford after talking to the house loans deparment at savings and loans and it only cost me $4.40!!!!!! That's unherd of..
But they don't have any instock and I'll get it tomorrow. Dads coming over tonight tho to have at look at it with me. But I'd much prefer to spend say $5. And find out it still leaks instead of 100+ and it still leak. Fair stoked fellas thanks again!! |
Smile
Haggle them on the price. See what happens
Critical Thinker
Ask them if they can offer pensioner discount.
#12 | |||
rexnet
![]() im 21 swapped the seal. looks to not be leaking. stoked! |
#13 | ||
Critical Thinker
Lol. At least its now sorted.
