Old 25-05-2009, 06:44 AM   #1
fmc289
Default kc laser 1.6
fitting another distrubtor, crank pulley to tdc #1 cyl at top of stroke
does rotor point to # 1 lead on the dizzy cap !!!! , as it seems to prefer
not to any help please. :
fmc289 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2009, 04:09 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
yes the rotor should point to the number one spark plug lead
you may only be out one tooth of the dissy cog
fit the dissy so the rotor is pointing to the number one plug lead
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2009, 12:01 AM   #3
smally289
growing up is optional
smally289's Avatar
Dont forget that number 1 will be at the top twice for each cycle. My guess is you are 180 degrees out. To get it right either whack your thumb over number 1 plug hole and flick the key to feel compression then line up your crank marks, or take the rocker cover off and check if number 1 inlet and exhaust rockers have clearance. If you are 180 degrees out, number 4 rockers will have clearance.
IIRC the dissy will only fit onto the cam in one position anyway (offset drive 'plate') so you cannot put it in wrong. Whack it in and see if it starts.
smally289 is offline   Reply With Quote Multi-Quote with this Post
