Old 02-01-2009, 12:01 PM   #1
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
Default Timing for 80 metre standing start sprint
Okay guys, we have a large collective pool of knowledge here and I am hoping somewhere amongst us is someone that has knowledge of accurate timing equipment.
Basically what I want to do is a repeatable standard acceleration test over around 80 metres of tarmac. To compare various models of ATV etc. in exactly repeatable scenario along an uphill tarmac slope on my property, a stig like standard acceleration test timed, speeds would be great also but times would do.
I am guessing I need basically a stopwatch/timer that accepts external inputs to trigger the start and stop.
Anyone ever set up this sort of rig?
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2009, 01:41 PM   #2
Buzz Box
Wheel Wally
Buzz Box's Avatar
Sorry did you want to know what time equals what speed?
IE. X secs = Y km's
Or do you want help to set up a laser rig so you just drive past and it automatically tells you?
Buzz Box is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2009, 05:35 PM   #3
Quicksand
Lucky, lucky bastard!
Quicksand's Avatar
You might be able to get away with using GPS tests or buy something like a G-Tech Performance Meter though i have heard mixed reports on how accurate the G-Techs are
2015 Mondeo Trend 2.0T Diesel, Deep Impact Blue
2012 FPV GT-P 6spd Auto, Lightning Strike
Quicksand is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2009, 06:16 PM   #4
mcnews
Trev
mcnews's Avatar
What I am after is either a pressure strip or laser beam that trips the timer to start and then one at the other end that stops the timer. So basically an accurate 100% exactly repeatable way to measure the time it takes to go from point a to point b.
Trev
Old 03-01-2009, 11:11 AM   #5
Zoink
Zoink's Avatar
FarmTek have a wireless, portable timing system for equestrian events that might suit your needs.
The timer and electric eyes run on batteries so could be set up anywhere.
http://farmtek.net/
http://farmtek-fti.com/download/brochure.pdf
Zoink is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2009, 11:23 AM   #6
BPXR6T
I use my GPS and an app called race chrono. I'd just average out a stack of runs.
BPXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2009, 11:31 AM   #7
Scott
Perhaps have a chat to your local Kart shop or look up Alfano on ebay etc. Very accurate timing, you would just need to add strips to the surface for start/finish and the Alfano will do the timing. Mychron is another popular brand.
With these units, you would need to fit them to each bike you test (rig up something quick/ish).
Scott is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2009, 10:59 AM   #8
mcnews
Trev
mcnews's Avatar
http://farmtek.net/
I think that looks like the go mate. Exactly the type of thing I am looking for, bit more $ than what I wanted to spend that's for sure but that is the type of rig I need.
Edit - Damn, I just realised it was USD too! That makes it very expensive!
Hmmmm. It does look the goods though.
Trev
Old 05-01-2009, 01:06 PM   #9
AndrewR_AUII
AndrewR_AUII's Avatar
Jaycar light beam kit $11.95 x 2
http://www.jaycar.com.au/productView.asp?ID=KG9094
Couple of cases, Roll of cable, wire up output relays to a stopwatch.
Not the prettiest and easiest to set up - but cheap as.
AndrewR_AUII is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2009, 01:35 PM   #10
mcnews
Trev
mcnews's Avatar
If you had the knowledge to set that up well you should start making the kits from those components and selling them. I can't even seem to find a stopwatch with external inputs. A friend of mine that does all the timing for the Aussie Superbike Championship etc. suggested some timing beams that he sources for about $120 each and wire them up to a stopwatch with external inputs which sounded like a pretty good set-up but I can't even find one of them!
Trev
Old 05-01-2009, 02:54 PM   #11
Scott
I've made those kits before and 5m is a stretch, particularly outside in the elements.
Old 05-01-2009, 03:17 PM   #12
mcnews
Trev
mcnews's Avatar
I was thinking the same myself. It looks as though the only real system is a 1.5k ask. But I have to be able to offer accurate and repeatable results, I mean like if I say Honda model x ATV does my acceleration test in x seconds and Yamaha model x ATV does it in ? seconds then obviously either Yamaha or Honda are not going to like it and I have to have something better than mates with stopwatches to back it up etc. GPS offerings etc. won't do etc. It has to be pretty damn accurate and 100% repeatable.
Trev
Old 05-01-2009, 03:36 PM   #13
Scott
Ok, I got it. get a stop watch and tie it to a tree. Attach an 80m long piece of cable and tie it to the bike...
Or - use one of these:
http://www.laurels.com/stopwatch.htm
With two of these:
http://jaycar.com.au/productView.asp...Max=&SUBCATID=
Wire the two PE Beams in series and you're done.
Old 05-01-2009, 03:43 PM   #14
mcnews
Trev
mcnews's Avatar
That might work, looking into it... Would need to run them off a generator I have or I could get the $30 optional adaptor kit and hook it up to a battery maybe... It also looks as though it would only display to the nearest second and not down to tenths etc.
Trev
Old 05-01-2009, 03:49 PM   #15
Scott
You'd want the relays to latch for a couple of seconds so the bike can clear the beam cleanly. Nothing worse than having the tyre trip it to start, the beams re-connect after the forks and then break as the engine goes past. If these are not configurable, you can get cheap timer relays (~$20 probably) that would create the delay you would need.
I expect the problem may only exist on take-off though.
Old 05-01-2009, 03:56 PM   #16
mcnews
Trev
mcnews's Avatar
Thanks for your help.
Trev
Old 03-02-2009, 05:33 PM   #17
Scott
How did you go?
