Old 25-01-2009, 07:35 PM   #1
XRMATE
regular user (not drugs)
XRMATE's Avatar
Default Ba/bf Roll Cages
Anyone got pictures of their roll cage be it sedan or ute ?
Can you buy pre fabricated bolt in ones that are ANDRA spec.
There is a lot of cars running tens so i would have thought some would have cages.
BLOWN BY BLUE POWER
TUNED BY CPV TUNING MACKAY
STOCK INTERNALS,DIFF,BOX
BEST 60 FT = 1.57
PB 11.10 @ 124 MPH
BA XR8 MKII 4SP AUTO SHOCKWAVE
TWIN 3" CUSTOM EXHAUST
XRMATE is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2009, 08:50 PM   #2
FPV+fteT3
Performance Inc.
FPV+fteT3's Avatar
Brown Davis in victoria did mine in the ute, bolts inn with taxi bar and cross brace in main hoop and brace accross the top of windscreen on front section. Tried to get Bond roll bars in Sydney to build one but when I told them the car was registered they wouldn't do it. Have few hassles getting it engineered with air bags and clearances.
Check with an engineer what you need to do before getting anything done if you want to keep it street legal. Harnesses are also engineered on mine in NSW the harness must need a tool to be removed so you can't use the clip on type must be a bolt inn setup.
Easier to put a cage in a car without air bags, the RTA says you can have nothing foreward that could prevent the air bag deploying so your cage has to come down behind the steering wheel and very much left on pass. side. Note this is a grey area some engineers just say no. Then there is clearances to your skull to contend with.
In The Garage...
FPV Super Pursuit Build no 0080/91
Lotus Exige S/C S240
Kart Hasse Chassis 100J Power
Originally Posted by flappist
Rental cars, the equipment of choice to get to destinations where 4WDs fear to drive......
FPV+fteT3 is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2009, 06:17 AM   #3
Des Flurane
This has to be the best cage installation I have ever seen.
From 2005, more pics on XRTurbo forums. You have to reg to search though.
2007 BF Typhoon 11.79@117
Des Flurane is offline   Reply With Quote Multi-Quote with this Post
