Old 10-01-2025, 12:20 PM   #1
Default Cleaning Exhaust Soot Off Brick Walls
Pretty much as the title says, unpainted brickwork stained from cars backing up to it, or the initial blast of soot when they start back up after being parked.
Will something like Kenco degreaser shift this in conjunction with pressure washing? Doesn’t need to look like new, just well-maintained 20+ years old. This is my job for Sunday, cleaning the workshop forecourt!
Ideally fishing for recommendations that are budget friendly due to surface area (so, not high end detailing products), can be applied in a timely manner and are readily bought. Also, products can’t be too far either way on the pH scale due to risk of efflorescence or corroding ties.
Old 10-01-2025, 01:22 PM   #2
whitelion65
whitelion65's Avatar
Default Re: Cleaning Exhaust Soot Off Brick Walls
Channel your inner Banksy and make it a feature!
Steve
Current rides
2012 Mondeo Titanium wagon (TDCI)
Moondust silver
2016 Focus Trend, 1.5ecoboost, 6sp manual.
Frozen white
Previous
2004 Berlina Wagon (LS1) Vespers Blue
1995 Camry 2.2, white
1971 Ford Fairmont wagon 302w, C4 Polar white
1971 TC Cortina, 2L 4sp, Ermine white
whitelion65 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2025, 01:31 PM   #3
I love the idea, unfortunately customers are mostly not likely to “get” it, and Strata could have other ideas, too.
Old 10-01-2025, 04:15 PM   #4
EBSXR6
EBSXR6's Avatar
How big of an area do you need to clean?
EBSXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2025, 05:16 PM   #5
Say one metre high by about eight lineal metres. It’s slightly irregular, taking in hob walls and some columns. Typical besmirching:
Old 10-01-2025, 08:06 PM   #6
Itsme
Itsme's Avatar
What wrong using brick acid, avaialble from any hardware, it will also probably spruce up your concrete driveway.
Old 10-01-2025, 09:40 PM   #7
EBSXR6
EBSXR6's Avatar
Steam clean the Bricks.
Old 11-01-2025, 11:39 PM   #8
Crazy Dazz
I'd say that you would need repeated treatments, alternating between Degreaser, a Sugar Soap, and Bleach, followed each time by pressure washing.
Problem is that bricks are relatively porous, and most of the soot will be insoluble.
Crazy Dazz
Kicking Hippies in the Balls since 1966
Old 12-01-2025, 05:05 PM   #9
When I used to listen to talkback radio, I remember Shannon Lush would suggest using plaster of paris to remove oil stains from concrete or porous surfaces.
Mix Plaster of Paris into a stiff paste, she said you should be able to stand a knife up in it. To every cupful of this mixture, add a teaspoonful of liquid dishwashing detergent. Spread this paste onto the oil patch and let dry completely, the chip away the remove.
Old 12-01-2025, 05:16 PM   #10
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Washing powder mixed into a paste strips it right off the floor in my garage and the brick driveway after I let the car sit and idle for too long (dumper pipe)
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 12-01-2025, 09:00 PM   #11
I ended up having to wing it a little, time pressure was upon me (shop reopens to the public tomorrow). Kenco degreaser at 1:2 does a pretty lame job on heavy oil and soot, even with multiple soakings from a pump sprayer.
Think the bricks are exposure grade, they’re pretty tough and I laid into them without any surface shedding. Graffiti was cleaned up with paint stripper and the pressure washer, forecourt concrete lost 60% of its greasy tracking stains and the walls are about 80% better overall. Roller door was filthy (I hadn’t noticed!) and that came up well. Five hours of two blokes, two pressure washers.
Will try a test patch with laundry detergent poultice, not sure if I can substitute Basecoat 45 for Plaster of Paris to try the other recipe.
Thread Tools
Display Modes
